Activity › Forums › Adobe After Effects › Getting curved path points between keyframes
  • Getting curved path points between keyframes
    Posted by Matt Shoesmith on June 13, 2016 at 10:51 pm
    I have a simple horizontal path on a keyframe.
    On the next keyframe I have an S shaped path.
    How can I get better curves on each line point during the transition between those 2 keyframes? Right now the bezier handles aren’t being adjusted enough causing the in-between frames to have corners on each point.
    Matt
    Kalleheikki Kannisto replied 10 years, 3 months ago 3 Members · 2 Replies
  • Tudor “ted” jelescu
    June 14, 2016 at 7:53 am
    post a screen grab.
    Tudor \”Ted\” Jelescu
    Senior VFX Artist
  • Kalleheikki Kannisto
    June 14, 2016 at 1:18 pm
    It is often easier to handle keyframe bezier curves if you separate the dimensions.
