Activity Forums Maxon Cinema 4D Getting animated noise on every surface
  • Getting animated noise on every surface
    Posted by Richard Windsor on February 13, 2014 at 7:50 pm
    I am working on a comp and all of a sudden every surface when I render it out as a movie has a grain to it that looks as if its animated noise. Not sure what in the lighting I screwed up to get it to do that and can’t seem to figure it out. Any ideas?
    Adam Trachtenberg replied 12 years, 7 months ago 2 Members · 5 Replies
  • Adam Trachtenberg
    February 13, 2014 at 10:50 pm
    Are you using GI (irradiance) or AO?
  • Richard Windsor
    February 13, 2014 at 11:12 pm
    I am using AO
  • Adam Trachtenberg
    February 13, 2014 at 11:15 pm
    First thing I’d do is turn off AO and see if that clears it up. Other things that can be noisy are GI, area shadows and blurry reflections/transparency.
  • Richard Windsor
    February 13, 2014 at 11:35 pm
    Will give those a try when I render it next time and see what happens. If it is the AO what settings do I need to modify to get rid of it? I have to have the AO.
  • Adam Trachtenberg
    February 14, 2014 at 3:29 am
    Increasing the AO samples and/or quality will reduce the noise. It might also help to lower the distance.
