Activity › Forums › Adobe After Effects › Getting After Effects to Recognize More Ram
  • Getting After Effects to Recognize More Ram
    Posted by Ashley Ripka on January 18, 2013 at 9:34 pm
    I just installed 32GB of RAM on my computer. When I go to render it stating that I am only using 4% of the total RAM. How can I get After Effects to increase the percentage of RAM used on CS6?
    Todd Kopriva replied 13 years, 8 months ago 2 Members · 1 Reply
  • Todd Kopriva
    January 18, 2013 at 10:54 pm
    Where, exactly, are you seeing this 4% value? It’s likely not telling you what you think it is. Just paying attention to how much RAM the foreground application is using tells you very little, since it’s the background rendering processes that are consuming most of the RAM when you’re rendering.
    Also, as Dave says, the goal is not to use all of your RAM; the goal is to render fast and well. If RAM isn’t the bottleneck (e.g., because you’re rendering something that is computationally expensive and thus the CPU is what’s being taxed), then some other part of your system is working flat out while your RAM is not much needed.
    See this page for resources about making After Effects work faster: https://adobe.ly/eV2zE7
    After Effects team blog
