Activity Forums Adobe After Effects Getting a curved illustrator shape to “draw on”
  • Getting a curved illustrator shape to “draw on”
    Posted by Max Palmer on October 16, 2012 at 7:52 pm
    Hi guys- I have a logo design that I want to animate on. It has curved sections that I want to “paint on”. Normally I’d just use the Writeon effect, but I also want to be able to scale or zoom out of the shape plus have continously rasterize on to maintain sharpness. I can’t find a technique that will work the way I want, once I make the shape 3d. Is there an easy way to do this with a mask? Here is what the shape looks like:
    Max Palmer replied 13 years, 10 months ago 2 Members · 2 Replies
  • Andrey Sibiryakov
    October 17, 2012 at 12:05 pm
    Hi Max.
    Yes, you can do it by animating your mask as alpha channel for the logo curve. You need only to precompose mask with logo layer, and then make it a 3d. You will be able to continuously rasterize it still.
    You can achieve write on effect with a shape layer drawn on above your curve and applied stroke after. this stroke can be animated and used as alpha.
    I would prefer the second method.
  • Max Palmer
    October 17, 2012 at 1:03 pm
    Thanks Andrey- after fussing around yesterday, I was able to get the effect to work great with Trapcode 3d Stroke.
    But, that second method- you’re saying that you can apply the stroke effect to a path on a shape layer, and then animate the stroke? I’ve never used that technique, but I will try it in the future.
