Activity › Forums › Apple Final Cut Pro Legacy › Getting a clean export
  • Getting a clean export
    Posted by Martin Banks on July 20, 2005 at 9:12 am
    I’m trying to export a sequence to become a self contained quicktime that I can import into after effects. The problem is is that with whater ever setting or compressor I seem to try none of them give me a good crisp video, they all look like there are parts that have been de-interlaced. When I have used Premiere 6.5 and have exported my timeline as a Quicktime using the Sorensen 3 compresser at 75% the images have been close to perfect. I was wondering if I have overlooked a setting in final cut pro that would make the results from the same settings look bad.
    any help is greatly appreciated as I have quite a few clips to export!
    Cheers,
    Martin
    Bryce Whiteside replied 21 years, 2 months ago 3 Members · 5 Replies
  • Walter Biscardi
    July 20, 2005 at 11:27 am
    I simply export using the same settings at the timeline. Then you need to be sure in AE to Interpret Footage correctly. Never had an issue with the video dropping in quality in 4 years using this method with FCP.
    Automatic Duck export is even better since it retains the original clips in AE.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Martin Banks
    July 20, 2005 at 11:46 am
    Thanks, I’ll give it a try. I’m also have another problem, don’t know if you can help butI thought I’d ask. I have made some clips in AE, and need to get it from a Mac into Avid PC. I put the AE clips to tape using FCP and then try to import the clips into Avid. When I do this the video again seems to have interlacing problems, except the lines are more like separated parts of the vdeo than interlacing lines. The thing is when they play back on the tape they are smooth, it’s only when it goes into avid….so maybe this a question for the avid forum. I’ve tried adding flicker romval and de0interlacing but with not results.
    the shot is of a track past an object with a white background, and I’ve been told that sometimes programs have issues with pure white background….could this be my problem?
    I hope someone can help.
    Cheers,
    Martin
  • Walter Biscardi
    July 20, 2005 at 1:06 pm
    For getting material to a PC, simply render in the Lossless settings in AE wiht the correct frame size, field interpolation as the non-linear editor you’re going to. I do this as well for an AVID Editor. I render 720×486, lower field first, using the Lossless setting. I also render transitions with Alpha Channels for her using Lossless+Alpha. All seems to work well.
  • Martin Banks
    July 20, 2005 at 1:46 pm
    I tried exporting it from AE as a lossless quicktime with Lower field first, and I’ve also tried exporting it as with field off, and I’m still getting the “cracks” in the video, and when I import it into Avid Xpress DV the colours change which is a big problem, the whites go yellow. I wish it would just work!
  • Bryce Whiteside
    July 21, 2005 at 6:56 pm
    From a post by Fred P. on the eyeon Software Digital Fusion List at
    LAFFEY Computer Imaging Fusion Resources:
    “Here is how we are attacking the problem of the gama flag in quicktime
    movies causing movies made on the pc to look dark when played on macs.
    After the movie is created, you need to execute the following command
    from a shell.
    gsar.exe -sgama -rgggg -o filename.mov
    obviously, to do this, you need the gsar program which can be found at
    https://www.jsifaq.com/subL/tip5800/rh5801.htm
    -s is the search flag, so it is searching your movie for the “gama”
    attribute
    -r is the replace flag, so in this example it is replacing gama with
    gggg which means nothing to quicktime, so in effect it has no effect on
    the movies gama correction at playback any longer.”
    Note that the “gama” is not a misspelling. This hack was created by researching
    QuickTime File Format Specification Documentation
    You would think that there would be a Use or Not Use Gamma switch in applications like QuickTime Pro and FCP for export alternatives for cross platform compatibility.
    Inquiring minds…
    Bryce
    Don’t worry Mr. B. I have a cunning plan…
    PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
