Activity Forums Adobe After Effects Getting 2D track data into AE
  • Getting 2D track data into AE
    Posted by Navarro Parker on November 7, 2012 at 8:10 pm
    I have a text file that contains exported data from PF Track. It contains 2D tracker information that I want to use in AE. How would I apply this data to a 2D AE null?
    The data is in this format:
    # "Name"
    # clipNumber
    # frameCount
    # frame, xpos, ypos, similarity
    "Eye InnerL"
    1
    119
    1 888.875000 646.375000 1.000000
    2 889.500000 646.218750 0.993040
    3 889.656250 646.250000 0.992075
    Vishesh Arora replied 13 years, 10 months ago 3 Members · 2 Replies
  • Kevin Camp
    November 7, 2012 at 10:32 pm
    you might try to hack ae’s clipboard for position data and fool it into pasting your data — which sounds more complicated that it is — try this…
    in ae, create a simple position animate (two keyfames should be enough). then select them and choose edit>copy.
    then open a text editor and choose paste. you should see something that looks similar to what you have above.
    delete the numerical data that was just pasted (bellow the ‘frame,’ x pixels, ‘y pixels,’ ‘z pixels’ header and above the ‘end of keyframe data’) and paste in the data that you have (bellow the 119 line).
    you’ll want to use a single tab between values and i think you’ll also want to delete the last column of data (it starts with 1.0000) since ae will interpret that as z pixels.
    then select all of that and paste it into the position property of a null (or other layer) and see if that works.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Vishesh Arora
    November 8, 2012 at 7:28 pm
    Navarro
    I have transferred the data from Pftrack text file to Ae.
    Here is the file which may help you to understand:
    4928_trackingdatafrompftracktoae.zip
    From the above file, Copy:
    Adobe After Effects 8.0 Keyframe Data
    Units Per Second 29.97
    Source Width 1
    Source Height 1
    Source Pixel Aspect Ratio 1
    Comp Pixel Aspect Ratio 1
    Transform Position
    Frame X pixels Y pixels Z pixels
    1 888.8 646.3 0
    2 889.5 646.2 0
    3 889.6 646.2 0
    End of Keyframe Data
    But I think the tracking data is incomplete as it is just for three frames.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
