Get rid of excess geometry in chain-link fence?
Hi there, I just whipped together this chain-link fence using like.. 60 cylinders
https://img694.imageshack.us/img694/1228/fencei.jpg
Anyway, how can I get rid of the excess in the edges? I don’t want to resize as it resizes from the middle, so one end would be shorter than the other, and then It would muck up the positioning if I moved them.
I also tried booleans, I got a large cube, covered the area I wanted subtracted and moved the wires underneath the cutting object (object A, the cube) and nothing happened. For good measure I tried it the other way round too, didn’t work.
Is there something like 3Ds Max’s slice tool? Because if I was on 3Ds Max I would group all the fences together, make them editable, then line up the slice tool, slice through the geometry and delete the unwanted parts, BAM, done. Alas, it isn’t as simple on C4D 🙁
Can anyone help me out here? Thank you.
