Activity Forums Adobe After Effects Get position data of area with highest value each frame of a sequence
  • Get position data of area with highest value each frame of a sequence
    Posted by Simon Ender on July 23, 2010 at 8:43 am
    I’m trying to find a way that after effects gives me position data of the brightest spot each in frame of a sequence. I have to add lightning to a very long sequence and I want the lightning start to position itself automatically at the brightest spot of each frame in my sequence. Like tracking, but not tracking motion, but the highest value in a sequence over time. Does anyone know how I could achieve that? With a plugin or script or on board tools?
    Simon
    Chris Mcfall replied 15 years, 4 months ago 3 Members · 4 Replies
  • Michael Szalapski
    July 23, 2010 at 2:52 pm
    You could crush the levels and use motion tracking, but it’s probably something that should be done by hand.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Simon Ender
    July 23, 2010 at 6:13 pm
    Thanks for your reply. I tried something like that, the problem is, the footage has 25 Megapixel resolution and the tracker freaks out, when I crank up the search area that big.
    Finding the brightest spot(s) in an image is such a simple thing, I think there must be a way to get the position of those areas. Image Lounge’s “Highlight Selection” plugin finds all that spots an makes twinkles where they are, but I can’t figure out how to get/reveal the data it uses.
    Simon
  • Simon Ender
    July 23, 2010 at 11:07 pm
    The thing is, that I don’t have to track a point that moves within a certain area. What I did is the following: I created the illumination the lightning causes on the cloud footage (approx. 10000*2500px) by the means of an animated turbulence. Now I have clouds that are randomly illuminated over time (1-2 frames each time). The only thing that is missing is the lightning strike. And since the sequence is more than 1500 frames in duration I want the start point of the ‘advanced lightning’ filter of AE to automatically place itself in the/an illuminaed area/s which are the areas with the highest value. The end point would than have to be offset accordingly via a simple expression.
    I’d appreciate any hint on that. But maybe I have to do it manually. It’s just that one would think that it is kind of an easy thing for some plugin or filter to find the brightest spot/s and output the position.
    Thank you,
    Simon
  • Chris Mcfall
    May 3, 2011 at 11:09 am
    Hii Guys Did anyone ever find an answer to this? I’m in exactly the same boat, trying to set a null to track the brightest point…
