Activity Forums Adobe After Effects Expressions Get folder path and save the path in app.settings, and change the path when required
  • Get folder path and save the path in app.settings, and change the path when required
    Posted by Nathaniel Logan on November 13, 2018 at 3:03 pm
    I need a small help on an After effects CEP panel script that I’m working on.
    What I’m trying to achieve is,
    1. If settings does not have a path – prompt user to select a folder. If path exists in setting:
    1.1. Check if its a valid path (if path exists). If it does, continue as normal.
    1.2. If path does not exist – prompt user to select a folder and save it to settings.
    2. Create another button in UI to change the path.
    Attaching the Link to my project files:
    https://drive.google.com/open?id=1TV40yER5wE3dIglGgSBNkccMlOpg0n69
    Much appreciated your time and your help.
    function getProjectFolder(){
    var targetFolder = Folder.selectDialog("Import Files From Folder");
    if (targetFolder){
    app.settings.saveSetting("Test Settings","Project Path",targetFolder.path + "/" + targetFolder.name);
    try{
    var saveFolder = File(app.settings.getSetting("Test Settings","Project Path"));
    catch (error){
    return saveFolder;
    var myProjectFolder = getProjectFolder();
    var path = myProjectFolder.path + "/" + myProjectFolder.name;
    Nathaniel Logan replied 7 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
