Activity › Forums › Adobe After Effects Expressions › Get an error when using pixelSampler from polygonstudio.com
  • Get an error when using pixelSampler from polygonstudio.com
    Posted by John Kevien on May 10, 2008 at 3:39 pm
    I was watching the tutorial from him,and tried to make a practice,but I got the error when I using the “pixelSampler”.
    this is the error prompted:
    After effects warning: Undefined value used in expression.Could be an out of range array subscript?
    expression disabled.
    error occurred at line 0;
    Comp:”Comp 1″
    layer:…..
    Property:’Reference Point’
    My AE CS3;
    Windows OS;
    the url is:
    https://maltaannon.com/articles/after-effects/ce-pixelsampler/
    and I got the error every preset he created.So sad.
    thanks in advance..
    John Kevien replied 18 years, 4 months ago 2 Members · 2 Replies
  • Lloyd Alvarez
    May 20, 2008 at 12:40 pm
    Hey John,
    Are you running AE in english? Expressions are language dependent and will break if they are not run in the same language that they were created.
    -Lloyd
    https://aescripts.com
  • John Kevien
    May 21, 2008 at 6:33 am
    Yes,My Operation System is English version of Windows,and My AE is English version too.So, if this is the key problem,how should I do? Change my OS version or AE version or the Script I had got!!
    thanks very much for your tip!!
