Activity › Forums › Adobe After Effects › Get a camera position from a image?
Michael Szalapski replied 5 years, 12 months ago 5 Members · 13 Replies
Konstantin Smirnov
September 22, 2020 at 9:37 amThanks, I’ll try that. I’am still a bit confused that there isn’t an easiler way then manually calibrating the camera position, the lens and the sensor
Michael Szalapski
September 22, 2020 at 3:00 pmI’m assuming it’s a video of feet walking.
And, yes, then he would just key the feet.
Michael Szalapski
September 22, 2020 at 3:03 pmIf the ground is moving at a constant rate (which, I would assume it is since it’s a treadmill), you could pretty easily just plop a plane there in 3d space as others have said and roughly get it right by eyeballing it. Then, when you animate the plane’s movement, you can make sure it’s moving in the right direction really easily.
How are you bringing 3d models in? Are you using Element 3d, Mir, Stardust, or something else?
