Activity Forums Adobe After Effects generation loss
  • Mylenium
    November 29, 2006 at 7:58 am
    Yupp. At least the segments that were modified will be re-encoded and show more artifacts.
    Mylenium
    [Pour Myl
  • --Bez--Bez--Bez-- Create COW Profile Image
    –bez–bez–bez–
    November 29, 2006 at 10:54 am
    should i export as lossless then?
  • Mylenium
    November 29, 2006 at 1:05 pm
    Yes and no. You can export the parts that are not going to be procesed further as DV, but areas where you want to add effects or transitions in Premiere should be lossless to avoid degeneration and artifacting.
    Mylenium
    [Pour Myl
    –bez–bez–bez–
    November 29, 2006 at 3:19 pm
    cheers
