Generate new random number on each “marker” and hold until next marker
Hello all,
As probably 99,99% of all AE users, this forum has tremendously helped me over the years… And I’m usually pretty good at piecing together a couple of expressions to make it work for me, but I am now struggling with this.I need an expression that will generate a random number on each marker. Hold that number until the next marker and then generate another number, and so forth.
The random number should be between 2 and how many layers I have in the comp.If you are wondering, I am trying to do an effect similar to what is described here, but instead of the layers flashing randomly, I want to be able to control every time a different layer is randomly displayed.
Thank you a lot !
Damien
