Activity › Forums › Adobe After Effects Expressions › Generate an x,y,z position for 100 layers
  • Generate an x,y,z position for 100 layers
    Posted by Kevin Church on March 10, 2010 at 10:37 pm
    I am looking for a way to generate an x,y,z position for 100 layers that remains constant through time. I have a pile of pictures that I want to place in different positions in 3D space without having to manually set the positions.
    I used the expression below, but the values are randomized each frame.
    Thanks in advance for any help!
    maxZ = 5000;
    minZ = -5000;
    maxX = 3000;
    minX = -3000;
    maxY = 2000;
    minY = -2000;
    z = random(minZ,maxZ);
    x = random(minX,maxX);
    y = random(minY,maxY);
    [x,y,z]
    Kevin Church replied 16 years, 6 months ago 4 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    March 10, 2010 at 11:30 pm
    just add this at the top:
    seedRandom(index,true);
    Dan
  • Kevin Church
    March 10, 2010 at 11:41 pm
    Thanks Dan,
    I am new to After Effects and new there would be an easy solution. Just so I understand, the true part is what makes this not sensitive to time?
    Cheers,
    Kevin
  • Dan Ebberts
    March 11, 2010 at 12:04 am
    Yes, that’s correct.
    Dan
  • Kevin Church
    March 11, 2010 at 12:32 am
    Thanks so much!
  • Darby Edelen
    March 11, 2010 at 1:27 am
    Dan’s already got your back on seedRandom(index, true); but I thought I’d also mention that random(); will accept a pair of vectors/arrays, so you could simplify your code to:
    min = [-3000, -2000, -5000];
    max = [3000, 2000, 5000];
    random(min, max);
    Darby Edelen
  • Lloyd Alvarez
    March 11, 2010 at 1:38 pm
    Using expressions is not the most efficient way to do this since expressions are evaluated for every
    layer at every frame. This is why I wrote a script to do this. The script only
    needs to he evaluated once at run time. https://aescripts.com/3d-layer-distributor/
    Lloyd
  • Kevin Church
    March 11, 2010 at 6:56 pm
    cool, thanks for the tip! That code is much cleaner.
    Lloyd, I am not too familiar with scripts but I like the theory. I’ll take a look at your link.
    Thanks everyone!
