Activity Forums AJA Video Systems General KONA LH capture question
  • General KONA LH capture question
    Posted by Uli Kunkel on December 16, 2005 at 10:53 pm
    I’m getting a new Kona LHe. I know that it doesn’t support upconversion. However, if I plug my DSR-25 into it the COMPOSITE IN on the card and use rs-422 control, will I be able to capture as DVCPRO50? If so, will timecode come over as well?
    Ron Thompson replied 20 years, 9 months ago 3 Members · 3 Replies
  • Ron Thompson
    December 17, 2005 at 6:31 pm
    Yes, and Yes.
    Just make sure your settings are correct and Kona/FCP will do the rest.
  • Michael Alberts
    December 18, 2005 at 4:19 pm
    Yes, but why would you want to. A DV signal, converted to analog, passed along via composite, then transcoded into DV50. Yikes, that’s gonna look horrible. If it’s strictly for offline and you plan on doing an online later than that’s fine. But composite? At the very least you should be using S-Video.
    Michael Alberts
    Ambidextrous Productions, Inc.
  • Ron Thompson
    December 18, 2005 at 6:48 pm
    I agree…S-Video at the least. I use this setup with a DSR20.
