Activity Forums Apple Final Cut Pro Legacy General Error or Out of Memory Continued Frustrations
  • General Error or Out of Memory Continued Frustrations
    Posted by John Orchard on July 18, 2012 at 6:24 pm
    Hi everyone! I’ve been searching this forum and have done the solutions provided in some of the workarounds, i.e. deleted preferences etc. I’m still having the same issue: I export a 60 second 1920×1080 QT animation codec sequence from After Effects CS6, import into FCP 7.0.3 and mix audio. I then try to export directly from the timeline, File>Export>Using Quicktime Conversion. Almost immediately I get the “General Error” or “Out of Memory” error. I’ve tried re-exporting out of AE to no avail. Incredibly frustrating. If I export 1280×720 from AE and try the same thing I get no problems however. What gives? I need this to be full HD. Please help!
    MacPro 2×2.4 ghz quad
    64GB RAM
    NVIDIA Quadro 4000
    John
    Bret Williams replied 14 years, 1 month ago 3 Members · 2 Replies
  • Jerry Wise
    July 18, 2012 at 8:04 pm
    i would run your animation codec thru Compressor and convert to ProRes 422HQ.
  • Bret Williams
    July 18, 2012 at 11:47 pm
    64 GB RAM??? Wow. What are you doing with an old MacPro that you are coming close to even needing 1/4 of that? Time to eBay some of that while it’s still gold. 🙂
