Activity › Forums › Apple Final Cut Pro Legacy › General Error – One solution to particular problem.
  • General Error – One solution to particular problem.
    Posted by Josh Evans on October 15, 2008 at 11:37 pm
    Just thought I would post this in case it helps someone else.
    I kept getting general error every time I tried to render my timeline, or export using compressor.
    I tried redering it in halves, but got the same error.
    Eventually, I started to render it in small chunks, which worked for some of the timeline. Basically I kept doing this until I narrowed the timeline down into bits that would render, and bits that would not. In the parts that would not render, i kept rendering smaller and smaller chunks – process of elimination – until i found the – literally – few frames here and there that for some reason were corrupt. It was just a few frames in a few clips in certain places along the timeline. I just removed the frames and patched them up with alternate shots and now it all works.
    Hope this helps someone else…
    David Bogie replied 17 years, 11 months ago 2 Members · 1 Reply
  • David Bogie
    October 16, 2008 at 6:41 pm
    [Josh Evans] “Hope this helps someone else…”
    It sure will. Thank you for posting this information. the “general error” is so useless but at least we have some realworld experience to refer others to, “Look for corrupt image files or movie files, no matter how difficult it might be to find them.”
    bogiesan
