Activity › Forums › Apple Final Cut Pro Legacy › General Error on text
  • General Error on text
    Posted by Del Holford on June 6, 2008 at 7:09 pm
    I have a two minute timeline with the bottom layer a QT background animation. Above it I’ve tried a QT from Live Type and a text effect from Video Generators. I’ve tried superimposing and direct overwrite. These clips only last 3 seconds. Every time I try to render them I get a General Error. What am I missing? Thanks.
    MacPro Dual 3 Ghz processor, 3 Gb RAM.
    Del
    fire*, smoke*, photoshopCS3
    Charlotte Public Television
    del underscore edits at wtvi dot org
    Del Holford replied 18 years, 3 months ago 2 Members · 2 Replies
  • Tom Wolsky
    June 7, 2008 at 2:16 pm
    Can’t tell. It may be a disc writing issue. Could be a lot of things. Unfortunately General Error is not very informative. Could you send me the project file and the LT file? I don’t need the background animation. I’m assuming that’s in the same format as the sequence settings.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Del Holford
    June 9, 2008 at 3:12 pm
    Hi Tom
    Thanks for the response. I shortened the LT clip by 2 seconds I didn’t need and then replaced the typewriter effect I’d inserted Friday with the LT clip again. I started the render then canceled about 50% through as the error occurred after 65%. Then I’d render the next bit. That worked. The project is 1920×1080 and is pushing the system pretty hard. Since it’s now hunky dunky I’ll not take more of your time. Thanks again.
    Del
