Activity Forums Apple Final Cut Pro Legacy “General Error” message
  • “General Error” message
    Posted by Natasha Paulson on March 30, 2009 at 7:03 pm
    I’ve been working all night on a project. I have Final Cut 6.0.4. I’m trying to render this tiny bit of image, but every time I go to render it a “General Error” message pops up with no options. It also happens when I try to export to Quicktime.
    Any suggestions? Thanks!
    Shane Ross replied 17 years, 5 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    March 30, 2009 at 8:32 pm
    [Natasha Paulson] “I’m trying to render this tiny bit of image, but every time I go to render it a “General Error” message pops up with no options.”
    Is it a still image?
  • Shane Ross
    April 2, 2009 at 11:51 pm
    #47 – GENERAL ERROR when rendering
    Shane’s Stock Answer #47 – GENERAL ERROR when rendering
    Getting a General Error when you try to render is most often caused by a clip on the timeline that has an inconsistent frame rate.
    SOLUTION: Rebuild the suspect clips – either by exporting from Quicktime Pro with recompression, or Conforming the clip to the project’s frame rate using Cinema Tools.
    Shane
