Activity Forums Apple Final Cut Pro Legacy general error exporting from FCP to QT
  • general error exporting from FCP to QT
    Posted by Tim Pearce on September 20, 2005 at 1:11 am
    I have searched through the old posts and found no
    solution to my problem (I had tried some solutions or
    they were slightly different problems). I am getting a
    “general error”(no error #) when I try to export my
    sequence using “File>export>quicktime movie” command.
    I need to export in order to make a DVD. I am new at
    FCP and the first (and only other time) I exported a
    sequence (different file), I got this error. I noted
    how far alone ( % complete) and found the location on
    my time line. I cut a hunk out and tried to export it
    again. this time it worked. I am now working on a
    second project and I got the same error. I took out
    many bits of my sequence, thinking that this would
    help, but all it does it get me further towards a
    completed export before it stops. (i.e 6% complete,
    20%, 42%, 60%…). I am sick of spending 30 or 40 mins
    waiting untitl it errors out. I have been hacking at
    my sequence in an effort to remove any problem
    footage. this has not been a problem as I’m just
    exporting all my rough footage to make a DVD. I can
    take bitts out of this because I don’t need the full
    scenes. but soon i’ll have a rough cut and will want
    to export my complete sequence.
    I’ve been doing troubleshooting with my computer and
    FCP.
    1. I did a “safe boot” and “repaired permissions” on
    my root drive.
    2. I trashed my “preference files” and restarted FCP.
    3. Out of curiosity I deleted the title clips on the
    V2 layer and exported. it didn’t work.
    4. I copied one clip at the beginning of the sequence
    to another new empty sequence and exported only it. It
    worked.
    5. When I tried to export the complete sequence, the
    export errored out the progress bar read 18% complete.
    so I took that clip at 18% from the start of my time
    line. I tried to export only that clip. It failed. I
    chopped out the footage around where this single
    problem clip failed and tried to export it again. It
    worked. Is it possible that the original master clip
    was some how corrupted or captured wrong? I watched
    the offending clip right around the fail point and
    couldn’t see anything wrong.
    6. I “saved as..” to make a new version of the project
    and have been using that.
    I captured my footage using OFFLINE RT settings if
    that makes any difference. Thank
    I am using FCP 5.0.2, OS 10.4.2, and QT 7.0.1. my
    computer is a new apple powerbook 17″ G4 and I’m
    usinga Lacie 250GB external drive.
    thanks for any help!! I’m slowly going insane… 😉
    Tim Pearce replied 21 years ago 1 Member · 0 Replies
  • 0 Replies
