Activity Forums Adobe Premiere Pro GeForce GTX 285
  • GeForce GTX 285
    Posted by Kyle Macdonnell on December 3, 2011 at 3:11 pm
    I can’t get Premiere to playback without the picture jerking and freezing. I am looking at the Tech specs Adobe Premiere web page. I have a Mac Pro Quad-Core Intel Xeon 2.4 GHz (the newest model) I am wondering if this card will work in my machine. Adobe also says that you need a monitor that will run at 1280×900. I have a Samsung SyncMaster 1920 x 1200 @ 60 Hz. (Which doesn’t list 1280 x 900). Will my monitor run at that resolution with the GeForce GTX 285?
    Any advice on getting Premiere to work on my system will be much appreciated!
    Alex Campbell replied 14 years, 9 months ago 4 Members · 6 Replies
  • Vince Becquiot
    December 3, 2011 at 5:48 pm
    Hi Kyle,
    I would double check that you have the correct driver, as well as the Cuda driver.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Tim Kolb
    December 4, 2011 at 7:54 pm
    [Kyle MacDonnell] “Adobe also says that you need a monitor that will run at 1280×900. I have a Samsung SyncMaster 1920 x 1200 @ 60 Hz. (Which doesn’t list 1280 x 900). Will my monitor run at that resolution with the GeForce GTX 285?”
    The 285 will fill two 30″ displays with no problem.
    The Adobe resolution spec is a minimum…more is great…less will not allow the entire UI to be visible.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Vince Becquiot
    December 4, 2011 at 9:15 pm
    Thinking about it now, if you are seeing this message, you likely have no driver or a default driver installed.
    If you check your display pref, you’ll probably a really low resolution set by default.
    Vince Becquiot
    Kaptis Studios
  • Kyle Macdonnell
    December 5, 2011 at 12:19 am
    That makes sense about the resolution. Will installing the GeForce GTX 285 or a Quadro 4000 make my playback work? I am using SATA drives with external RAID firewire drives. Thanks
  • Vince Becquiot
    December 6, 2011 at 1:53 am
    That should do it.
    Vince Becquiot
    Kaptis Studios
  • Alex Campbell
    December 15, 2011 at 9:59 pm
    The playback will also depend on what you are using for a codec. If you are editing something like an h.264, you may not get great playback unless it is rendered.
