Activity › Forums › Apple Final Cut Pro Legacy › Garbage Matte Rendering Problems???
  • Garbage Matte Rendering Problems???
    Posted by Norman Greenwood on July 9, 2008 at 10:08 am
    I have to mask a lot of things for a movie I am doing, so I downloaded a 50-point plug-in to get as precise as possible.
    I used it to cut out a small jagged hole in a clip. I put a picture beneath that clip, and it was showing up fine UNTIL I RENDERED!
    I tried messing with the filter features, and the compositing modes, but as soon as it finished rendering THE CLIP WOULD APPEAR AS A BLACK SCREEN. I thought that maybe it was the plug-in, and tried the 8-point garbage matte, but the same thing happened.
    Is there a setting I need to change? What can I do to make these masks work?
    -N
    Norman Greenwood replied 18 years, 2 months ago 2 Members · 2 Replies
  • Arnie Schlissel
    July 9, 2008 at 10:15 pm
    If you need to animate the mask, you’d be much better off doing this in Motion, AE, Combustion, Shake or Silhouette Roto. If you don’t need to animate the mask, then use Photoshop.
    FCP’s garbage mattes are very low powered, and those 36 & 50 point freebies are pretty sucky.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Norman Greenwood
    July 9, 2008 at 10:27 pm
    I was originally going to use Motion 3, but lately, every time I bring a clip into it and add behaviors or filters it just freezes or crashes.
    I guess it was really that FCP was being iffy with me. It suddenly started working today (the computer was on all night though). It actually came out pretty good.
    Thanks for the help.
