Activity Forums Avid Media Composer GarageBand export key change upone import into Media Composer 7
  • GarageBand export key change upone import into Media Composer 7
    Posted by Frank Bokoski, jr. on June 11, 2014 at 3:05 pm
    I created a simple droning synth audio file in GarageBand. When I import it into Media Composer 7, the key of the music is changed. Lowered almost a whole step. I’ve tried exporting AAC and mp3 (the only choices in GarageBand) yet get the same result. I’ve converted the file to wav….same result.
    What is going on here?
    1615, The GC Media Project
    http://www.1615.tv
    Frank Bokoski, jr. replied 12 years, 2 months ago 1 Member · 1 Reply
  • Frank Bokoski, jr.
    June 11, 2014 at 4:20 pm
    I figured out the problem. I run audio output from the media composer through an MBox Mini. The problem is the mbox mini not liking the project sample rate.
    http://www.1615.tv
