Activity Forums Apple Final Cut Pro Gap between clips when copy paste from one project to another
  • Gap between clips when copy paste from one project to another
    Posted by Thanos Papadopoulos on September 13, 2017 at 10:43 pm
    I duplicated my project and I needed to do a copy paste from my previous project. Then I noticed a gap between my clips. Also some audio clips have lost synch because the connection of the audio clip with the primary story line has moved to the gap.
    I tried for a sideway to do it. I selected some clips and created a compound clip. I double clicked the compound and I saw that the clips also had a gap between them.
    Are there any thoughts?
    Fix it in Pre.
    Jeremy Garchow replied 8 years, 11 months ago 2 Members · 6 Replies
  • Jeremy Garchow
    September 14, 2017 at 3:37 am
    The Projects have different frame rates?
  • Thanos Papadopoulos
    September 14, 2017 at 5:57 am
    I checked project settings and its the same. It should be the same since I duplicated the sequence. Also when I make a compound clip it also adds a gap between clips inside the compound. So even if the two projects had different frame rates what’s the point putting gaps in the compound which I make inside the original project?
    Fix it in Pre.
    September 14, 2017 at 6:18 am
    Now I see that its putting a gap even when I copy-paste clips even inside the same project. I guess it’s some kind of gap.
    Fix it in Pre.
  • Jeremy Garchow
    September 14, 2017 at 3:17 pm
    Instead of duplicating, try making a new Project.
    Does the footage not match the frame rate of the Project?
    Do you have retiming applied?
    I have seen these gaps appear before but it’s when the footage and Projectbframe rates don’t match, or have been placed in a Project with a different frame rate and pasted in to another frame rate. Especially when the frame rates are close , like 24 vs 23.98, or 23.98 vs 25, etc.
    September 23, 2017 at 9:29 pm
    There is some material with different frame rate. But fcp x supposed to have no problem with mixed frame rate. Also I wanted to simplify my timeline to send it to davinci so I put all my clips to my primary storyline.
    I had two ways to do that
    A. with the position tool drugging down the clips
    B. With the shortcut cmd+ alt+ down arrow.
    Bothways there were some clips that there was no way of going straight down. The clips were going a few seconds back or forward like they had anothere place in the primary storyline than the secondary.
    Fix it in Pre.
  • Jeremy Garchow
    September 23, 2017 at 10:10 pm
    [Thanos Papadopoulos] “But fcp x supposed to have no problem with mixed frame rate. “
    Sometimes it does.
