Activity Forums Apple Final Cut Pro Legacy gammashifts on external monitor
  • gammashifts on external monitor
    Posted by Peter Frick on February 13, 2006 at 2:21 pm
    Hi. I’ve got a problem, when I start using the default window setup for colorcorrection i fcp. My external videomonitor becomes lighter whenever the video is not playing. Very frustrating since I don’t see what I get when I colorcorrect. The problem is also that even though I go back to my default setup this problem remains. As soon as I play something from the anvas or in the timeline and it stops, I get a gammashift, the picture gets lighter in my monitor. If I look at the sourcematerial in the viewer everything is ok.
    I’ve got a new G5 a blackmagic videocard and the sourcematerial is on an X-raid connected to the system via fiberoptics.
    My guess is that it has to do with the videocard. Has anybody got any ideas?
    Peter Frick replied 20 years, 6 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    February 13, 2006 at 6:09 pm
    Was this footage rendered out of After Effects by any chance?
    If not, then I know there used to be a thing with Blackmagic cards where you turned off the overlays in the canvas (timecode, title safe and other wise) and the shift went away. That was a while ago though and perhaps their driver updates have fixed this.
    Jeremy
  • Peter Frick
    February 14, 2006 at 11:09 am
    This is just straight material DV Pal, not rendered through AE.
    I’ll look into it with the black magic peolpe but all the overlays are turned on.
  • Peter Frick
    February 14, 2006 at 11:35 am
    Hi again. The problem went away when I entered user-library-preferences and dleted the two cachefile in fcp user prefs
    at least this solved the problemfor now. Thanks for your input anyway.
