Activity Forums AJA Video Systems Gamma shift while capturing dual link in ProRes 444
  • Gamma shift while capturing dual link in ProRes 444
    Posted by Arthur Puig on July 23, 2010 at 6:07 am
    I’m digitizing dual link in Prores 444, against single link in ProRes 444, and I can see that the dual link has the blacks at around 10 or so, whereas in single link is at 0.
    How can I fix that?
    Fred Connors jr. replied 16 years, 1 month ago 3 Members · 5 Replies
  • Gary Adcock
    July 24, 2010 at 10:58 pm
    Ok
    You know the drill, machine specs, software and OS versions…
    Are you using an easy setup or did you modify an rgb setup.
    What is your original? A Log file often looks flat while that single link will be under Rec 709 ( check my blog for a log recording vs. a linear rec 709 of the same clip.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Technology Development
    Quality Assurance Assistance
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Arthur Puig
    July 25, 2010 at 7:15 am
    Using Mac Pro octo, Kona 8.0 drivers and FCP 7.0.2, digitizing dual link in Prores 4444 from a HDCAM-SR, blacks are lifted. Blacks are OK when digitizing from HDCAM-SR in single link in ProRes 4444
  • Fred Connors jr.
    July 26, 2010 at 1:40 pm
    It is 7.5 not 10, and it is usually in the setup playback preferences of the HDCam deck
    Fred
    The Troupe – Modern Media Design & Production
  • Gary Adcock
    July 26, 2010 at 2:07 pm
    [Fred Connors Jr.] “It is 7.5 not 10, and it is usually in the setup playback preferences of the HDCam deck”
    THERE IS NEVER “SETUP” IN DIGITAL FORMATS
    sorry fred,
    gary adcock
    Studio37
    Chicago, IL
  • Fred Connors jr.
    July 27, 2010 at 1:03 pm
    I stand corrected, Gary.
    There is the option the add setup to the composite out, I was mixing my outputs.
    Fred
