Activity Forums Apple Final Cut Pro Legacy Gamma shift btwn QT6.5 10 bit and QT7 10 bit
  • Gamma shift btwn QT6.5 10 bit and QT7 10 bit
    Posted by Paul Mcglaughlin on August 2, 2005 at 11:39 pm
    Hi all-
    We’re just starting to switch over to FCP 5, Tiger and QT 7. We’re running into an issue where we export a TIF from QT 6.5 using the Blackmagic Codec (QT 6.5.x), do some manipulations in Photoshop, and re-import into FCP. On our FCP 4.5, Panther machine, it has a gamma shift if we render in YUV, but not if we render in RGB (in Timeline Options). In FCP 5, there is a gamma shift regardless. Are there any workarounds for using the BM 10 bit codec in FCP 5?
    Jerry Hofmann replied 21 years, 1 month ago 2 Members · 1 Reply
  • Jerry Hofmann
    August 3, 2005 at 1:13 pm
    Why not just import the tiff into Photoshop, then import that saved and tweaked file into FCP and edit with it? FCP needs stills like that in RGB Mode too BTW… CMYK will drive things nuts.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
