Activity Forums Apple Final Cut Pro Legacy Gamma issues
  • Posted by Thomas Mikkelsen on January 27, 2010 at 10:11 am
    Hey everybody
    I have a issue with the gamma settings on apple machines.
    I am running Leapord with FCP 7. I know that with leapord the gamma display standard is 1.8 and when you install snowleapord you get gamma 2.2 as a standard. When working with quicktime files ProRess and H264 (offline aproval) you can under qt preferences setup Enable Final Cut Studio color compatibility when final cut is installed.
    What if i callebrated my display to 2.2 and ads that setting under qt pref, what is then correct ?
    If i render a proress 4:2:2 HQ and set my gammaprofile to automatic the QT preferences fcp dosent do anything. But when i drag my file into Finalcut pro the file looks brighter than in quicktime ?
    Does annybody know annything about these gamma issues ?
    Thomas Mikkelsen
    Editor
    M2film.dk
    Thomas Mikkelsen replied 16 years, 8 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    January 27, 2010 at 4:19 pm
    [Thomas Mikkelsen] “What if i callebrated my display to 2.2 and ads that setting under qt pref, what is then correct ?”
    As far as I know, you will be double correcting which would mean that you aren’t correcting. Id’ leave the display at 1.8 and leave the FCP color box checked.
    [Thomas Mikkelsen] “If i render a proress 4:2:2 HQ and set my gammaprofile to automatic”
    You mean in the QT dialog? I always leave that at none, unless I am switching gamma profiles (601 to 709 or similar). Where are you doing your ProRes rendering? That will help answer the rest of your questions.
    [Thomas Mikkelsen] “Does annybody know annything about these gamma issues ?”
    Yeah, they are no fun and you can only really judge the quality of your work on a true video monitor hooked up a to video capture/output device.
  • Thomas Mikkelsen
    January 28, 2010 at 1:10 pm
    Thanks for the feedback.
    I am rendering from After Effects to Final Cut pro.
    Thomas Mikkelsen
    Editor
    M2film.dk
