Activity Forums Adobe After Effects Gamma / Color Shifts: Importing QT files from FCP
  • Gamma / Color Shifts: Importing QT files from FCP
    Posted by Heath01 on March 19, 2007 at 1:51 pm
    Hi All,
    I’ve had gamma/color shift problems between FCP and After Effects since I started using the two programs. I understand what’s going on with the whole YUV space vs RGB and FCP’s automatic gamma assumptions, but I was hoping someone can outline an easy solution / repeatable workflow to avoid this issue once and for all. Any tricks out there?
    Cheers,
    Heath.
    Kevin Camp replied 19 years, 5 months ago 2 Members · 1 Reply
  • Kevin Camp
    March 19, 2007 at 4:28 pm
    i havent worked with fcp much, but generelly if i need to effect clips in ae, i will always use the nle to do the conversion from yuv to rgb (using a lossless or uncompressed codec) and again from rbg to yuv at import.
    you can make the adjustments in ae using the expand 601 levels in the interpret footage panel, and then create an adjustment layer to knock them back down to 601. but since i don’t know exactly what the expand 601 levels is doing to the footage, i can’t be sure my levels adjustment is the exact reverse. so there may be shift. if its all done in the nle, then hopefully it’s more consistent.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
