  • Posted by Adrian Germain on November 10, 2007 at 5:15 pm
    Hi all. I’m trying to translate a cellular automaton script to an after effects animation and i have a question. My idea is to put opacity switchers to each cell layer and to manage them from a null layer. Could i do this with indexing? Thanks.
    Dan Ebberts
    replied 18 years, 10 months ago
    2 Members · 4 Replies
  • Dan Ebberts
    November 10, 2007 at 6:08 pm
    I think I’d do the life calculation in a text layer. You can play around with the idea by applying this test expression to a text layer:
    s = “”
    numDigits = 10;
    for (i = 1; i <= numDigits; i++){ s += Math.round(random()); if (i < numDigits) s += ","; } s Then apply this opacity expression to 10 solid layers (make sure they're above the text layer in the layer stack): s = thisComp.layer("control layer").text.sourceText.split(","); if(parseInt(s[index-1]))100 else 0 That should give you the idea. Dan
  • Adrian Germain
    November 12, 2007 at 9:10 pm
    Thanks a lot Dan.
    Just one thing.
    When you say:
    which is the condition?
  • Adrian Germain
    November 13, 2007 at 3:42 am
    I’ve made a 3X3 cell like this:
    123
    456
    789
    On the text layer i used:
    f=timeToFrames(t = time + thisComp.displayStartTime, fps = 1 / thisComp.frameDuration, isDuration = false);
    b=f.toString(2);
    b.split(“”,10);
    It looks like a time binary counter but something is wrong.
    binary scheme not in sync with frames number.
  • Dan Ebberts
    November 13, 2007 at 2:40 pm
    You know, you don’t actually need the commas. I modified your binary counter to this ten-digit counter:
    f=timeToFrames( time);
    (f+1024).toString(2).substr(1);
    Then used this opacity expression:
    thisComp.layer(“control”).text.sourceText.substr(-index,1)*100
    Dan
