Activity › Forums › Apple Final Cut Pro Legacy › gain levels not working
  • gain levels not working
    Posted by Patrick22 on January 6, 2006 at 9:38 pm
    I’m capturing component 10-bit uncomressed to a Kona 2 and I’m having trouble with the audio gain levels. When I try and adjust them in clip settings it isn’t rasing the levels. Any idea how to remedy this?
    Jeremy Garchow replied 20 years, 9 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    January 6, 2006 at 11:23 pm
    Do you have the Kona Control Panel installed?
    If yes: go to the setup tab and look at the audio setup. Is the “Lock input Audio Gain to Unity” checked? If yes, uncheck but buyer beware, this could mess up your settings later on.
    If no, then my advice would be capture as it is and “fix it in post”.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
