Activity Forums AJA Video Systems G5 sees a kona2 as a PCI and not a PCI-X
  • G5 sees a kona2 as a PCI and not a PCI-X
    Posted by Joseph Bradley on June 1, 2009 at 12:32 am
    I have a G5 2.0 dual with a Kona2 card. it is in slot 3. The card was recently repaired. i put it in and it did not work. When I went to the info tab it said that the card was operating in PCI mode and there should be a PCI-X card in that slot. I am running 10.5.5 so I used the 6.0.3 driver. I then uninstalled it and tried the 5.1 driver with no change. I trashed the prefs of the Kona and Quicktime but no luck. Any help would be appreciated.
    Rob Larose replied 14 years, 8 months ago 2 Members · 3 Replies
  • Rob Larose
    December 14, 2011 at 6:33 pm
    Hi Joseph,
    I’m experiencing this same issue right now — do you by chance remember what solution you landed on?
    –Rob
  • Joseph Bradley
    December 14, 2011 at 9:30 pm
    The number four slot was unavailable to me because of the screws on the chassi were bad. I ended up getting a new machine and an LHe card.
  • Rob Larose
    December 14, 2011 at 9:42 pm
    Bummer. 🙂
    Thanks for the response! 🙂
    –Rob
