G5 built in soundcard analog to digital conversion noise ?
I have tried to find some info on it in terms of use.
not much luck . . .
The only thing I see is some talk of noise problems because of the internal fans . . .My question is: Is the noise caused by the analog to digital conversion process ?
Will this still be a problem using a TOSLink input ? (optical port)
My plan was to use my Korg D16 harddiscrecorder for the analog to digital conversion, and then us the optical input to get maximum quality 24 bit sound into the mac.
Would most of you pro sound people out there say this is a decent solution for ok quality audio ?
Will have to get a proper soundcard later, but for now im hoping this will do ?!!Any thoughts ?
[tecnical info on the Built In Sound Card:]
Devices:
Texas Instruments TAS3004:
Inputs and Outputs:
Line Level Input:
Controls: Left, Right
Playthrough: No
PluginID: TAS
Headphones:
Controls: Mute, Left, Right
PluginID: TAS
Internal Speakers:
Controls: Mute, Master
PluginID: TAS
Line Level Output:
PluginID: TAS
Crystal Semiconductor CS84xx:
Inputs and Outputs:
S/PDIF Digital Input:
Controls: Mute
Playthrough: No
PluginID: Topaz
S/PDIF Digital Output:
Controls: Mute
PluginID: Topaz
Formats:
PCM 16:
Bit Depth: 16
Bit Width: 16
Channels: 2
Mixable: Yes
Sample Rates: 32 KHz, 44.1 KHz, 48 KHz
PCM 24:
Bit Depth: 24
Bit Width: 32
Channels: 2
Mixable: Yes
AC3 16:
Bit Depth: 16
Bit Width: 16
Channels: 2
Mixable: No
