Activity › Forums › Panasonic Cameras › G4 rewrapping MXF, Do I need G5?
  • G4 rewrapping MXF, Do I need G5?
    Posted by Indyplayer on May 3, 2006 at 6:26 pm
    I have read on here and DVXuser that when you use a G4 it has to rewrap the MXF and it loses some resolution. Is this true? Any truth in this. Currently I am using a G4 dual 1.25 I put in a PCI USB2 slot. Do I need a G5? I am hesitant to upgrade becaues of all the costs, ie, new ram, new monitor adaptor, new drives.
    But the question remains..does the G4 reduce the quailty? Any drawbacks?
    Jason
    Noah Kadner replied 20 years, 5 months ago 2 Members · 1 Reply
  • Noah Kadner
    May 3, 2006 at 6:53 pm
    It’s not to do with processor speed- it has to do with how FCP handles P2. The video data is not being altered in any way. The MXF file header is being removed and replaced with a QuickTime header. Again- you are not losing any quality, resolution, etc from the original data. That said, more power will certainly serve you with more render power and faster editing- but again zero effect on ingest quality.
    Noah
