Activity Forums Apple Final Cut Pro Legacy G4 dual 1 gig and any aja or decklink setup question
  • G4 dual 1 gig and any aja or decklink setup question
    Posted by Evelvillian on March 9, 2007 at 6:54 am
    Hey everyone, i was wondering can i use an old mac G4 dual 1 gig with either of the AJA or decklink setups.
    NO AJA IO do not want any fire wire setups, only want to use PCI boards or what ever board.
    thanks a lot
    Matt Short replied 19 years, 6 months ago 3 Members · 4 Replies
  • Steven Gonzales
    March 9, 2007 at 2:14 pm
    That machine only has the older PCI slots. You would need a newer machine with PCIe or PCI-X slots.
  • Evelvillian
    March 10, 2007 at 1:55 am
    I have either a PCIe or PCIx system because ui have a caldigit drive system hooked up to it and that uses a sata pcie or pcix card, but i dont want the card to be a slave to that system i want to be able to put it into a new mac pro also.
    any suggestions would be great
  • Steven Gonzales
    March 10, 2007 at 5:01 am
  • Matt Short
    March 11, 2007 at 12:26 pm
    I have a Decklink SP in my G4 Dual 1.42 and it works fine. I can even monitor HD material through it to my broadcast monitor. You’ll have to get a PCIe card when you upgrade to a Macpro. The only way to upgrade your IO from a G4 to a Macpro (without an expansion chassis) is to go with firewire.
