Activity › Forums › Apple Final Cut Pro Legacy › G4 500, FCP4 and no RT question
  • Steve Eisen
    February 10, 2006 at 6:58 pm
    Make sure the Jumpback is a QuickTime MOV file. 720×480 DV-NTSC.
    If its settings do not match your sequence settings, then you will have to render.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Reuben Zuazua
    February 10, 2006 at 7:16 pm
    Thank you for the reply
    The JB is a mov file, and I did check the settings apple 0 and apple 9 and they match. but for whatever reason anything i drop on the time lines requires a render. i will re install FCP and try things again
    thank you
    Reuben Zuazua
    After Hours Production
    graFX Artist
    indie@afterhoursproduction.com
