Activity Forums Storage & Archiving G-Speed, Apple OS SSD PCI-Express Or Sabrent 8TB
  • G-Speed, Apple OS SSD PCI-Express Or Sabrent 8TB
    Posted by Amir Hussian on October 1, 2020 at 9:32 am
    Hello Guys,
    I am comparing between using G-Speed Vs Apple SSD PCI-Express Or Sabrent 8TB for Premiere video editing for full 4K.
    Price-wise G-Speed 8TB is costing 5000$ & Apple Mac OS SSD 8TB is costing 2300$.
    Sabrent is costing 1500$ for 8TB !
    Read\write speed almost similar ( around 3 GB/Sec ) which is sufficient to do 4K video editing smoothly.
    Obviously, going to Mac SSD is cheaper but my concern is using the same mac OS SSD for both operating system & video editing at the same time.
    Any advice?
    Neil Sadwelkar replied 5 years, 11 months ago 2 Members · 1 Reply
  • Neil Sadwelkar
    October 12, 2020 at 8:51 am
    I had to Google these to find out what you are referring to.
    From what I could gather, you are comparing,
    1. getting an internal Apple 8TB SSD fitted in your MacBook Pro at the time of purchase for an additional $ 2,200, vs
    2. getting an external Thunderbolt RAID the G-Technology G-Speed Shuttle SSD for $ 4,800, vs
    3. a Sabrent RocketQ 8TB SSD (SB-XTMQ-8TB) which is a PCIe SSD in a Thunderbolt 3/USB 3.2 case for $ 2000.
    The G-Speed model you mention, is a 4-bay 3.5″ RAID fitted with 8 2.5″ SATA 1TB SSDs getting you 8TB formatted as RAID0. The RocketQ and the Apple SSD are actually comparable to each other as they are both PCIe NVMe SSD, one is internal and the other is external.
    There is something very convenient about having a large storage inside you MBP vs one hanging off a cable, so if that kind of hyper portability is important, then there is no contest. Get the internal SSD. There is no detrimental effect of having one’s OS and data on the same drive as far as I can tell. I use my internal MBP SSDs to back up huge amounts of data off camera cards while doing other things like dailies grade or sync off the same SSD.
    If having all that data available to any other system is also important, then get an external SSD. The Sabrent RocketQ is not the only one available in that capacity and form factor, so, shop around. For example take a look at OWC’s Thunderblade SSD RAID (2 SSDs), or the OWC Express 4M2 SSD RAID (4 SSDs). Even Netstor makes a handy 4-way PCIe SSD enclosure with a small fan too. Actually, considering the heat these SSDs produce when reading/writing, it might be a better idea to use external SSDs. The MacBook Pro is anyways quite ‘thermally challenged’.
