Activity › Forums › Storage & Archiving › G-Raid/Data Rescue – Bad recovery files
  • G-Raid/Data Rescue – Bad recovery files
    Posted by Kim Bo on January 6, 2015 at 6:01 pm
    I’ve got an G-Raid 8TB external hard drive. I had problem with the drive, it was always ejecting by itself… So I needed to back up all my videos files, and I used Data Rescue 4 to recovery all the files since my external hard drive was always ejecting by itself and I was not able to use it anymore.
    Once I did all the back up of my files, I format my external drive.
    But, now, from the flies that I recovered, I’ve got video files that are fragment, that are very bad. So I call for some support to Data Rescue, and they told me to do a deep scan. But my external hard drive always eject by itself, so I’m not able to complete my deep scan.
    Anyone could help, what should I try or do…
    Gene Gilbert replied 11 years, 8 months ago 2 Members · 7 Replies
  • 7 Replies
  • Gene Gilbert
    January 7, 2015 at 8:46 pm
    Hi Kim,
    Thanks for your post. Which G-RAID model do you have, is it the USB 3.0 version? If so, the disconnecting issue you are seeing may possibly be addressed with a firmware update. Here is a link to the firmware updates: https://support.g-technology.com/support/firmware-updates
    You may also contact me directly at eugene.gilbert@hgst.com for further assistance. Please let me know if you have any questions.
    Regards,
    Gene Gilbert
    g-technology.com
  • Kim Bo
    January 7, 2015 at 8:52 pm
    This is the model I got: G-Technology 8TB G-RAID External Dual-Drive Storage System
    The link of the firmware update you send me it’s for G-Drive. Is it the same I need to use?
    I will try to do the update! Hope it will work
  • Gene Gilbert
    January 7, 2015 at 9:00 pm
    Hi Kim,
    There is a G-RAID update on there as well, I believe it is the 4th one down, says G-RAID v5. If your G-RAID has one USB 3 port and 2 Firewire 800 ports, then this update would be for that model.
    Regards,
    Gene Gilbert
    g-technology.com
  • Kim Bo
    January 7, 2015 at 9:26 pm
    It doesn’t work… I did the update, then I run Data Rescue to try to recovery my files… but the hard drive still eject by itself. I install G-Raid v5 like you suggest me. And yes my hard drive have one USB 3 port and 2 Firewire 800 ports.
  • Gene Gilbert
    January 7, 2015 at 11:32 pm
    Did you cycle the power by turning the drive off and back on? That is necessary for the update to work.
    Regards,
    Gene Gilbert
    g-technology.com
  • Kim Bo
    January 8, 2015 at 12:07 am
    Yes I did… and it’s really said that I’ve got the lastest update
  • Gene Gilbert
    January 9, 2015 at 4:59 pm
    Have you tried using the USB port? If it also does it on the USB port it most likely is an issue with one of the drives in the unit. I would recommend a data recovery company and replacement of your drive.
    Regards,
    Gene Gilbert
    g-technology.com
