Activity › Forums › Apple Final Cut Pro Legacy › G-RAID2 FW 800 drive
  • G-RAID2 FW 800 drive
    Posted by Jack Entonces on November 11, 2006 at 3:34 pm
    I’m a Mac newbie. Just bought a MacBookPro to edit Final Cut Studio.
    I have also bought a g RAID 2 FW external drive for editing, capturing video.
    Does anyone here have one? How is it installed to the Mac?
    The G-Tech site says it’s pretty strightforward, but just want
    to check with other users. Do I need to “partition” the drive?
    This is the part that worries me, I don’t know how to do that.
    Can someone help, advise, on how to install a GRaid2 FW drive
    to MacBook Pro?
    thank you.
    Walter Biscardi replied 19 years, 10 months ago 2 Members · 3 Replies
  • Walter Biscardi
    November 11, 2006 at 3:41 pm
    Just connect it to your FW800 port and turn it on.
    It will mount right up on your desktop, though you should give it a clean erase from your system.
    Go to Applications > Utilities > Disk Utility
    Select the G-RAID Drive. Select Erase. Select Mac OS Extended, NOT journaled. Select OK. Select OK again when it says you’re about to erase everything.
    We were using a brand new G-RAID2 1000 last week, but stopped using it after finding performance issue with a second FW800 drive attached to it. Also the speed on the G-RAID2 was slower than the original G-RAID 500 and 800 that we also run.
    As long as you run it by itself, you should be fine.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Jack Entonces
    November 11, 2006 at 9:53 pm
    What does it mean “give it a clean erase from your system?”
    Please explain.
    Thanks.
  • Walter Biscardi
    November 11, 2006 at 10:33 pm
    [JACK Entonces] “What does it mean “give it a clean erase from your system?”
    Please explain.”
    I already did, just follow what I said above.
