Activity Forums AJA Video Systems FYI – TESTED!!! IO FCP 4.5 – G5 Dual 2.7GHZ – OS 10.4 !!!!
  • FYI – TESTED!!! IO FCP 4.5 – G5 Dual 2.7GHZ – OS 10.4 !!!!
    Posted by Adam Schmidt on April 28, 2005 at 12:26 am
    Ok, so apple released the dual 2.7 GHZ G5 macs today, and I was first in line to buy one at the stonestown apple store. I came home and have been testing for six hours.
    The set up:
    G5 Dual 2.7GHZ
    MAC OS 10.4.0 Tiger
    512MB Ram (I have orderd 4GB)
    512GB SATA internal drive (have not conected the raid yet.)
    AJA io (full) Drivers 1.3.1 (I have not tested the beta control pannel yet)
    Sorce Deck: Sony J-30
    Formats: Dbeat and Beta SP
    Captured at: D25, D50, UC8bit, and UC10bit
    All 30min docs, all without drop frames, all works great.
    Hopped into Ae6.5, and video out works great (boy is this mac fast, makes AE look like motion).
    I don’t know what AJA thinks is wrong but everything worked.
    Now onto the UC10bit stress tests. I hooked up my Medea RTRS 320 to my UL4D ATTO card.
    Six UC10bit (tiled 3 top 3 bottom) Stream, no drop frame warnings.
    Started to add Color corection to the clips. First two and the “Safe- High” setting was still green.
    I added CC to 3 and the bar truned red. Droped down to “unlimited -high” and had an orange bar, but no drop frames.
    Added 2 more CCs (up to 6 clips, 5 with cc) and 7 minutes into the program I hit my first drop frame.
    DV (D25) tests: D25 playing out the io. 5 streams (tiled) three with CC, no drop frames.
    And this is all on 512MB or ram.
    Doing more tests, see this link for more info.
    Adam
    https://www.creativecow.net/forum/read_post.php?postid=111460296985419&forumid=8
    Adam Schmidt replied 21 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Adolfo Rozenfeld
    April 28, 2005 at 3:58 am
    Adam, if you don’t mind, I have an OT question. Would you please check in system profiler which model and brand the DVD burner is? I am about to buy a DL burner for my G5 and I would like it to be natively supported by Tiger, so knowing which one Apple is using would be very helpful. Many thanks!
    Adolfo Rozenfeld
    Buenos Aires – Argentina
    https://www.adolforozenfeld.com
    adolfo@adolforozenfeld.com
  • Adam Schmidt
    April 28, 2005 at 7:19 am
    ATA Bus:
    PIONEER DVD-RW DVR-109:
    Model: PIONEER DVD-RW DVR-109
    Revision: A912
    Detachable Drive: No
    Protocol: ATAPI
    Unit Number: 0
    Socket Type: Internal
  • Adolfo Rozenfeld
    April 28, 2005 at 7:45 am
    Thank you so much, Adam.
    Adolfo Rozenfeld
  • Tony! Hulette
    April 28, 2005 at 10:04 am
    [Adam Schmidt] “Ok, so apple released the dual 2.7 GHZ G5 macs today, and I was first in line to buy one at the stonestown apple store”
    Congrats on the new machine Adam! I’m jealous you got it so fast.
    [Adam Schmidt] “I don’t know what AJA thinks is wrong but everything worked. “
    Wow, that’s good news that everything is working fine so far for you. Its completely opposite of what multiple sources told me at the AJA booth during NAB. Basically, they all said the current Io was not compatible with Tiger and that we shouldn’t update the OS until the new Io drivers are released (sometime in May). I was also told the Io would need the new drivers for FCP 5. I should have followed up and inquired about what specific problems they were having when using current Io with Tiger and FCP 5.
    Let us know if you run into any problems.
    Tony!
  • Mitch Ives
    April 28, 2005 at 4:17 pm
    So, perhaps the Io is compatible with Tiger… maybe it’s not compatible with FCP 5 until you have the new drivers? A clarification might be nice…
    Mitch Ives
    Insight Productions Corp.
    mitch@insightproductions.com
    http://www.insightproductions.com
  • Mitch Ives
    April 28, 2005 at 4:21 pm
    [Adam Schmidt]
    I don’t know what AJA thinks is wrong but everything worked.”
    Adam, what firmware version are you running in your Io?
    Mitch Ives
  • Mitch Ives
    [Adam Schmidt]
    Mitch Ives
  • Adam Schmidt
    April 28, 2005 at 7:15 pm
    firm v26
