Activity › Forums › AJA Video Systems › FYI: ProRes capture on a Quad G5
George Bellias replied 19 years, 2 months ago 7 Members · 15 Replies
Walter Biscardi
June 18, 2007 at 5:39 pm[David Roth Weiss] ”
You should absolutely be able to capture ProRes 422 1080i/60 with your quad machine using the IO HD.”You can do ProRes Capture / Playback on a MacBook Pro too with the Io HD. That’s the whole point of the on-board processing. AJA had the unit hooked up to a laptop at NAB and it was working very nicely.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
David Roth weiss
June 18, 2007 at 5:43 pm[walter biscardi] “You can do ProRes Capture / Playback on a MacBook Pro too with the Io HD. That’s the whole point of the on-board processing. AJA had the unit hooked up to a laptop at NAB and it was working very nicely.”
And, what about the simultaneous high quality latte export???
David Roth Weiss
Director/Editor/Post-production Supervisor
David Weiss Productions, Inc.
Los Angeles -
Mark Palmos
June 21, 2007 at 7:19 pm[David Roth Weiss] “And, what about the simultaneous high quality latte export???”
aaah mr weiss, always looking for the perks hey?
looks like I may be joining the fcp bandwagon – a merger with a sister company who already have several fcp’s… more of that on the edit*ors forum… later mate,mark.
David Roth weiss
June 21, 2007 at 7:26 pmMark,
Welcome to the dark side (actually, the enlightened side). I think you will be happy (for the most part)… Plus, you’ll be able to lean on me and the others here during your trip over the learning curve. There are lots of great peeps here. My to you advice is, read everything that come across this forum and you will usually know what’s happening before you need to know it and before it affects you.
Keep me posted…
David
“No job is worth doing more than once…”
David Roth Weiss
Los Angeles -
George Bellias
June 22, 2007 at 2:58 amDavid,
Great to hear from you! We need to catch up. Send me your contact info.George
