Activity › Forums › Apple Final Cut Pro Legacy › FYI: Canon XH A1 & FCP 6
  • FYI: Canon XH A1 & FCP 6
    Posted by Mtnmedia on June 2, 2007 at 10:03 pm
    I just captured my first footage to disk from my Canon XH A1 using the Firewire cable. It imported perfectly using the Easy Setup (HD 1080I/24P) and compressed through Compressor with no problems whatseover.
    Sweet.
    I am using a MacPro Oc with 4 GB.
    Kevin Malin replied 19 years, 3 months ago 4 Members · 9 Replies
  • 9 Replies
  • Mtnmedia
    June 2, 2007 at 10:05 pm
    Should have read: Mac Pro Octo.
  • Miodrag Ristic
    June 3, 2007 at 12:07 am
    [mtnmedia] “compressed through Compressor”
    Compressed to … what format?
    Tried ProRes as well?
    It’s good to know, as I’m looking at XH A1 as well.
    Mick
  • Mtnmedia
    June 3, 2007 at 12:22 am
    Mick,
    I have compressed it through Compressor to a DVD/mpeg and HD DVD mpeg as well as straight out of FCP as a Quicktime.
    Great results every time.
  • Mtnmedia
    June 3, 2007 at 1:43 am
    [Miodrag Ristic] “Tried ProRes as well?”
    I just did… looks fantastic, but there’s something off with the render proportions, and the file size is huge. I need to learn more about setting up the options with that codec. But again, it looks great.
  • Eric
    June 3, 2007 at 8:22 am
    how
  • Mtnmedia
    June 3, 2007 at 3:49 pm
    Eric,
    All 8 CPU’s were engaged at about 50% throughout the compression. The clip was about two minutes, and took about between two to five minutes, depending on the number of passes in the encoding.
  • Eric
    June 4, 2007 at 10:28 am
    thanks for the numbers!
    though I
  • Eric
    June 4, 2007 at 10:29 am
    though I
  • Kevin Malin
    June 10, 2007 at 5:52 am
    Please help. I just bought a Canon A1 and FCS2. I’m having capturing problems. I want to shoot in HDV 24F, but when I tried a capture test, it didn’t work. What audio and video settings do I need to use for both the camera and Final Cut? Thank you for your help.
