Activity Forums VEGAS Pro FX panel went blank
  • FX panel went blank
    Posted by Jack Jockson on July 27, 2015 at 6:10 pm
    This is what happened to me. I want to crop something, a slice of video or still image, so I open Pan/Crop panel and this panel is totally blank now.
    Here’s the screenshot https://prntscr.com/7xnftc
    I don’t have the slightest idea what caused this crash. Everything worked all right the other day, except in the meantime I was configuring Windows a bit, changing themes and such. Help somebody if you can I’m in terrible troubles.
    https://videoartworks.blogspot.com/
    Jack Jockson replied 11 years, 1 month ago 3 Members · 4 Replies
  • Bob Peterson
    July 28, 2015 at 2:08 pm
    I suggest using the message button for Image Upload so that you can upload an image. That will overcome my reluctance to click on an unknown link.
  • Jack Jockson
    July 28, 2015 at 3:43 pm
    Here’s it.
    There’s nothing to see actually, a completely blank panel appears.
  • Danny Hays
    July 28, 2015 at 5:47 pm
    That is definitely not normal. Vegas is not running correctly. If restarting you PC doesn’t fix it, try “System restore” to a point before this started. If system restore isn’t enabled or doesn’t work (Error stating system restore did not work) try uninstalling Vegas and reinstall it.
  • Jack Jockson
    July 29, 2015 at 4:51 pm
    I did “System restore” and it worked. Thanks.
    It seems the problem was me upgrading some motherboard drivers or something.
