Activity Forums Apple Final Cut Pro “Fuzzy” Playback on FCPX
  • “Fuzzy” Playback on FCPX
    Posted by Nicolas Vallejo on December 28, 2011 at 1:15 am
    Hi –
    Working on a project shot on a Canon 5DMKII at 24 frames, 1920 X 1080, 1080p.
    My render format is Apple ProRes 4444.
    When I play back the footage on Final Cut, it becomes “fuzzy,” slightly blurry.
    However, once I stop it completely, it goes back to full resolution.
    This problem persists once I export the project.
    Any ideas of what the issue is?
    Nick.
    Jeremy Garchow replied 14 years, 9 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    December 29, 2011 at 3:29 pm
    Since you’re working in 444, FCPX is up sampling your footage to a much higher bandwidth on the fly.
    I would use normal PriRes for this, also choosing to transcode your footage will help with performance.
    I take it you are using the h264s?
    Jeremy
  • Nicolas Vallejo
    December 29, 2011 at 10:10 pm
    Yup. Working H264.
    I am on a MBP with 2.8GHZ and 8GB RAM.
    Will transcoding my footage result in quality loss when I’m exporting for the final product?
  • Jeremy Garchow
    December 29, 2011 at 10:49 pm
    No. You’ll be fine.
