Activity › Forums › Avid Media Composer › Further to Avid on a laptop-Firewire in PCMCIA slot
  • Further to Avid on a laptop-Firewire in PCMCIA slot
    Posted by David Mcsween on May 30, 2005 at 7:21 am
    Is there any reason not to run the firewire through the type II slot on the laptop? I realise that you can’t power it but I am happy to use the USB2 port for drives.
    The reason is that I have found a better spec laptop for same price minus the firewire port.
    Cheers
    David Mcsween
    Editor ABC Brisbane, Australia
    Cody Bettis jr replied 21 years, 4 months ago 2 Members · 1 Reply
  • Cody Bettis jr
    June 1, 2005 at 3:18 am
    Are you talking about an Avid Mojo on that firewire port or just a camera or deck for digitizing?
    A camera or deck will do just fine.
    As for a Mojo, depends on the laptop and card. A cheap firewire card in the slot will not work. Too slow. Also, either way you can definately NOT digitize via Mojo to the external USB drives, only internal drive. Check out Avid’s qualified laptops and their specs on the avid site and get something similar.
