Activity Forums Adobe After Effects Funny Lines
  • Funny Lines
    Posted by Gully Moore on October 20, 2008 at 1:46 pm
    When using PAL DV tape footage in After Effects i get strange flickering lines around the edge of my person when using the Keylight effect with a green screen.
    However there is no problem like this when using my hard drive recorder camera
    I guess this is a format problem? The hard drive camera records in NTSC and the DV in PAL? And after effects works in NTSC?
    If this is the case then can i set After Effects to PAL?
    Thanks very much
    Mark replied 17 years, 10 months ago 2 Members · 1 Reply
  • Mark
    October 20, 2008 at 2:35 pm
    After Effects will work in Pal/NTSC HD/SD…whatever you need pretty much. First, make sure that you properly interpret your footage (right click on footage in project window)…then set up your comp to match your footage.
    mark
    Mark Harvey
    Senior Editor
    Le Réseau des sports
