Functionality similar to Actions in Photoshop?
I’ve found myself doing repetitive process on every project I open. Stuff like: setting render and project frame rate, enabling alpha, choosing H.264 encoding, hiding background, adjusting the same material to the same amount and so on.. I always set some settings to the same value.
Is there some functionality in Cinema similar to Actions in Photoshop? in PS you hit record and perform a set of actions. This actions can later be done again with a simple click.
