Activity Forums Adobe After Effects fullscreen on second monitor
  • fullscreen on second monitor
    Posted by Giorgio Rinolfi on October 28, 2009 at 4:13 pm
    Hi all!
    I’m in CS4 and i need to work on second monitor full screeen.
    I’ve found and try this plugin tp://www.videox.de/
    but i can’t work on its window and also its have the normal border of a window.
    Instead i want to set the composition the same resolution of the native resolution of the second monitor and have the comp preview fullscreen on the second monitor.
    So use the first monitor for the interface and work on the second fullscreen, but a real one as i’m watching a movie full screen so without GUI border or window border.
    Any help is welcome
    peace
    Editing/compositing
    Digital Artist
    Pedro Monsalve replied 15 years, 11 months ago 2 Members · 2 Replies
  • Giorgio Rinolfi
    October 28, 2009 at 6:18 pm
    Uuu that’s a huge investiment for me atm.
    So do you think the only solution is a piece of hardware to have the composition preview full screen on the second monitor?
    Because i’m not using a professional MONITOR but a normal computer monitor so with DVI or VGA input.
    And also i’m on PC and i don’t know if the KONA support windows.
    Giorgio
    Editing/compositing
    Digital Artist
  • Pedro Monsalve
    October 12, 2010 at 5:45 pm
    OMG not sure if you found a workaround, but if you are working in SD, a quick non expensive workaround is plug-in a DV cam to you firewire, and output your ram preview through it.
    I worked this way for a little while to get accurate colors representations at a studio I freelanced for. Worked great, gave us a true representation of what most likely was going to look like on the worst case scenario.
    Hope this help.
