Activity Forums Web Design (WordPress, Joomla, etc.) Full Width Navigation Bar Problems
  • Matt Geier
    January 15, 2013 at 8:05 pm
    Hi Jamie.
    Thanks for posting.
    I’ve looked at the link and I don’t particularly see the issue.
    I appeared, normal.
    Can you specify what you’ve seen as the problem..
    Might also be helpful to know what broswer your running / have tested with.
    Matt Geier
    (Video Networking Solutions Expert)
    (Creative Design Workflow Consultant)
    (Social Media Networks Consultant)
    (Technical Video Industry Sales Consultant)
  • Demetri Tashie
    January 15, 2013 at 8:17 pm
    you need to work with/target either the li or the a element and change some settings.
    you could for instance give each list element a fixed width, or you could increase/play with the padding or margins.
    here is one way, which increases the padding of each a element inside the list element from 0.5em to 3.0em:
    #navMain ul li a {text-decoration: none;padding: 0em 3.0em;margin: 0;color: #fffffd;white-space: nowrap;}
    play around with that and see what you come up with.
    there are many other ways to accomplish this also. this is just one way.
    you can take a look at this pared down file here if that helps:
    5234_nav.html.zip
