Activity › Forums › Adobe After Effects › Full Resolution vs the lower resolution HELP
Posted by Jack Bob on January 14, 2009 at 5:06 pmI created an animation that deals with falling particles.
When rendering on “third resolution” the particles seems to be exactly where I wanted to be. But on “full resolution” the particles seems to be offset from the 3D-space.Roland R. kahlenberg replied 17 years, 7 months ago 2 Members · 3 Replies -
January 14, 2009 at 6:47 pmWhich particle system are you using???
If it’s Particle Playground then it does render differently, depending on your comp and layer settings.
Cheers
RoRKbroadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available)
Jack Bob
January 15, 2009 at 12:46 amI’m realizing that it isn’t the particles.
Actually, my problem is the compositions being rendered and being offset when working at full resolution and third resolution(or other lower resolution).
It seems to go out of the keyframe. I need to finalize and render them as full resolution, but since most of my work is done at third, the compositions isn’t animated the way it should be at full resolution. -
January 15, 2009 at 6:42 am[Jack Bob] “Actually, my problem is the compositions being rendered and being offset when working at full resolution and third resolution(or other lower resolution).
It seems to go out of the keyframe. I need to finalize and render them as full resolution, but since most of my work is done at third, the compositions isn’t animated the way it should be at full resolution.”That’s a bummer dude! I can’t think of a workaround but to tweak accordingly. Learn to solo layers or even use dummy layers and guides.
Good Luck
